Hi Steve, thanks a lot for the quick reply. I already figured that out what you have said, but just to a certain degree. I still having problems to make it work in a proper way.
When I used the BomeBox as a “Ethernet Master”, my WIFI was not working anymore, so I couldnt go the web. Becasue only one DHCP master is allowed on a network, right? When I turned it off again, it also takes ages to get back my internet WIFI connection. Can I use both? My WIFI internet and the BomeBox as a connection to the dadamachines, or is it not possible in that way? Or would it be better to use a fixed IP with the BomeBox or what would you suggest?
I also dont wanna use the home/office internet router with the Bomeboxes. I just need the BomeBoxes as a connection to the dadamachines preferably via Ethernet, via WIFI the latency would be too high, especially working with music. But I would need a internet connection every now and then to go to the web to download things or checking emails.
The situation would be as follows. We are in a theatre space and I am running Ableton Live on a Macbook Pro with USB-C only, to control the music, some lights and the dadamachines (https://dadamachines.com/products/automat-toolkit/). The distances are quite high, around 60 meters, so its only possible to use the Ethernet protocol. Thats the reason why I bought three BomeBoxes. From the Bomebox and can simply use a Midi cable to trigger the dadamachines automat. I tested it, and it worked already with one BomeBox. I also learned that I would have to rename the BomeBoxes if working with more than one … like BomeBox1, BomeBox2, and so on in order to make them work properly. I also have a Netgear Gigabit Switch GS305E in order to run three BomeBoxes parallel from my Macbook by the use of one USB-C connection only … there are only 4 on the Macbook and I need the other USB-C connections for other stuff. But I dont have a clue at the moment, how this works and if it works. I didnt tested it so far. I am also not quite sure yet, if I am able to run the BomeBoxes parallel like explained, or serial, like one after the other. So this would be main situation. When the theatre piece is running, for sure I will deactivate the WIFI anyway. I dont need it when the piece is on going. But I would also like to go to the web in order to download things or checking emails beforehand….maybe via WIFI or could be also the case that I have to use a cable. Those theatre institutions very often dont have WIFI, only a Ethernet cable. But in my studio I am only using WIFI.
One more question …. Connecting the Bomebox to Ethernet: In the top bar menu, do I always have to go to “Connect To” and then click on BomeBox? Is there a way to automate that? I also just realized I would have to got to “Network MIDI” via the WebConfig Tool and confirm it. Is there a faster way to do it?
Thanks a lot and looking forward to your reply, Martin
