yamahaqs300
2019-10-30 14:27:13
I need to send ribbon(CC16) to Pitch bend
Ribbon have 0 to 127 and when is released come to 64
Any help ? Thanks
yamahaqs300
2019-10-30 14:27:13
Any help ? Thanks
2019-10-30 14:57:24
Does the ribbon controller send any other MIDI message when it is released or are we going to need to use a timer to determine that? The timer would monitor changes in the CC and if no changes withing x ms set it back to mid point.
yamahaqs300
2019-10-30 16:14:55
after release ,he send to computer value 64 on MIDI Channel 1,2,3
2019-10-30 16:53:47
Hi, please find the attached. There are 3 translators
If you controller actually sets it back to center after ribbon release, you will only need the first translator.
yamahaqs300
2019-10-30 17:37:39
Brilliant !! You are my hero !!
2019-10-30 17:51:14
Glad to help!
