MikeDoor
2019-11-06 13:00:47
Hey,
I have convert 4 Midi notes into:
CC32 in CC94
CC33 in CC95
CC34 in CC96
CC35 in CC97
Now, if I press one of the converted midi notes, they are going on an endless loop to the last pressed button.
Example: pressing note CC33 it converts to CC95 and go directly in endlessmode down.
With the delay I can`t handle it. With Note on/off I can`t handle it.
With a shift switcher preset isn`t to handle.
I`ve tried some things but nothing seems to work.
Now I didn`t know anymore, how I could handle this thing.
Background:
I have took APC40 template on my DAW as a template for the APC40 MK II, to build new template with help of the old script.
Everything seems to work, only the scrolls didn`t wanna run correct.
Kindest regards
Mike
