dccullinane
2019-12-13 00:07:28
Hello! I'm trying to set up some Keystroke shortcuts and anytime I type Ctrl(M) it comes back as Ctrl(return).
"M" returns fine without pressing Ctrl. Some other charters also do not return the same when holding Ctrl.
Thoughts on this?
Thank you!
2019-12-13 00:36:26
Hi, I’m seeing the same thing on my Mac, but not on Windows.Are on you on Mac and maybe looking for CMD-M?
I’ll explore further. Perhaps on Mac Control-M is actually mapped to Control(Return)
dccullinane
2019-12-13 01:48:04
Hey Steve, I am using a mac for this. Thanks for checking both.
I also noticed that Ctrl(I) returns as Ctrl(Tab) . Not sure if that helps, but I wanted you to have that info
2019-12-13 01:56:11
Yes I noticed. Our developer is looking into this. I wanted to make sure I had Keyboard Maestro and OSCulator disabled on my Mac before I tried this as some applications will interfere or modify keystrokes.
