SteveC
2019-12-20 02:00:48
If anyone out there has an X-touch MINI and was disappointed that their Mackie emulation knobs do not control faders, I have set up a Bome Project that allows this. It even allows you to switch between Mackie ad Layer Modes with double tap of some controller buttons. You can also use the knobs as V-Ports by double tap.
The project exposes two Bome virtual ports (one for Mackie use and one for Layer use), so essentially it looks to your application like 2 separately operable controllers. All buttons and encoder values are saved so that it remembers them and updates LED rings and buttons as you switch mode.
Since I put in a lot of time on it, I will be charging for it if interested but at a reasonable price. If interested reach out to me via email as I will not be posting this project on the forum.
