Projector Control
csmdigital
2019-12-21 16:50:06
Has anyone tried or managed to control a projector with BMT Pro? I'm prettier it can be done via the serial port output option - may someone knows for sure?
Thanks Steve
2019-12-21 18:04:46
Hi, if the projector you will be using has a serial port and you know the serial commands and projector response you need, this could be done. I’ve helped someone in the past with camera control on an older video controller that only had serial port. Basically we convert MIDI commands (originating on a MIDI controller) to serial to send to the device and use the serial response back to determine if the command was successful.
I’ve also helped some to send serial to an Arduino to control relays for amp switching.
csmdigital
2019-12-22 19:34:34
Sound very promising - thank you for the help!
