Mandroid
2020-01-02 02:09:33
I've got an APC mini going through Bome to Ma2 OnPC 3.8.0.0. I've got temp buttons that work as expected when clicked - flash intensities to full, then release when the press is released. However when I trigger through my APC, the temp button stays on. Bome is registering both a "Note On" and "Note Off." Any ideas? Bome file attached.
2020-01-02 03:14:25
Yes, the APC-MINI sends note-off velocity at 127 (7F Hex) which confuses many applications (and even itself if you want to LED feedback) . You should be able to translate the note-off message as
Incoming:Note-Off MIDI Channel 1 set note to pp any velocity
Outgoing:Note-Off MIDI channel 1 note pp velocity 0
If you want raw output instead use:
90 pp 00
Make sure your incoming is directed from APC-MINI out outgoing to the virtual port you are using in GMA2.
This should fix the problem.
2020-01-03 16:35:20
Did this solve your problem? If so, please mark as resolved. If not, let me know and I will assist further.
Mandroid
2020-01-04 00:44:29
Ah, I see. Could you point me in the right direction to start learning about LED feedback/utilizing the LEDs? Not really finding anything helpful with a google search.
2020-01-04 00:53:35
Try this post. It is with APC-40 which sends the same for note off as APC-MINI.
https://www.bomeloft.com/support/kb/note-onoff-with-led-feedback
Mandroid
2020-01-04 01:31:53
Thank you for your time!!
2020-01-04 02:00:08
My pleasure!
