problem with switching APC40 to Mode 1
bkwillyard
2020-01-16 05:25:33
I am trying to change the mode of my APC40 and it is not working. This is what I have set up a Translator 1= incoming trigger Project opened with outgoing action of one-shot timer "APCInit": 1000ms delay Translator 2= incoming trigger: On timer "APCInit" with outgoing action: midi message Raw midi /System Exclusive F0 47 7F 29 60 00 04 41 08 02 01 F7 then i have specific ports selected and a check mark next to AKAI APC40 midi out port what connections do i need to make in my midi router?
2020-01-16 06:41:59
Translator 2 needs to send output to APC40 not Bome MIDI Translator 1.
Since you have an APC40 MKI (not MK2) the Init message should be:
F0 47 7F 73 60 00 04 42 08 01 01 F7
For MODE 2 or
F0 47 7F 73 60 00 04 41 08 01 01 F7
For mode 1
The one you are using is for APC40 MKII
2020-01-16 14:57:31
Looks like you got it working. Great!
