TJ Spurge
2020-01-25 17:49:06
Hello,
I'm wondering what kind of midi message is best for translating midi to keystrokes, specifically for Shift and CTRL (which I assume require a midi message to be sent continuously on a momentary control).
I'm trying to use cc messages and it doesn't seem to work. Is there a way to get shift and CTRL working properly? I think this is problem with the midi message and the fact that it doesn't send a value for the entirety of the button press, but only on the initial press for a split second.
