aplweb
2020-02-21 07:18:16
Is this possible? If so, could you recommend the expression? Thank you.
aplweb
2020-02-21 07:18:16
2020-02-21 18:54:46
Yes, this is possible.
There would be a translator for Note-On and another for Note-Off
You would both to the incoming channel you are using and set the note to pp and the value to qq
Then you would have rules that look something like this:
// default channel MIDI Channel 1
rr=0
if pp<80 then rr=5
if pp<50 then rr=4
if pp<30 then rr=3
if pp<10 then rr=2
if pp<5 then rr=1
Outgoing would be note-on for note-on incoming and note-off for note-off outgoing.
Outgoing channel would be rr
Note-on MIDI Channel rr note pp value qq
Note-off MIDI Channel rr note pp value qq
The rules are simple ranges setting to lower channels as range decrease. If you have gaps in the ranges then the rules would be a bit more complex.
aplweb
2020-02-21 21:21:04
