gderreck
2020-03-11 21:51:49
Greetings,
I am evaluating MIDI Translator Pro. For the most part, the program is very impressive. It is complex, but I believe there is a reward here for climbing the learning curve. However, there is an issue I would like to get to the bottom of.
I installed the program yesterday, then created and routed, the virtual ports. I then uninstalled Bome and installed another port driver/interface combination to test. It didn't take long for me to decide to uninstall the driver and router; and reinstalled Bome. After installing and creating the ports, I got warnings that the ports would not open. Here is a link to the files on OneDrive:
https://1drv.ms/u/s!AqnmatYsTMoHhagx6nQo3oDeiWuyJw?e=28jvqj
The files show Device Manager, The setup in the UI and the error messages in the program.
Looking in Device Manager, I saw, as the picture shows, that the ports were not functional. The previous virtual port driver was still in Device Manager, but it was not functional either (leftover after uninstall). I removed what was left of the old driver and then proceeded to manually install drivers for each of the nine Bome virtual ports, using the Wizard in Device Manager. That took care of the situation and the virtual ports were functional.
I decided to start fresh and reinstall. While I was in Device Manger, I attempted to uninstall a Bome virtual port. Device Manager became non-responsive and I had to hit the power button to get windows to shut down. After restarting the machine, I couldn't get past the POST welcome screen. Fortunately, I do daily backups, so I was able to recover the machine.
I rebooted into windows and reinstalled Bome. I got the same issue with the virtual ports not having drivers installed. The issue recreated itself exactly. The dead drivers for the other product I tested were gone. Having removed them earlier, they didn't sneak back in. I haven't manually installed drivers for all the ports yet, as I did the first time. I wanted to get some guidance here before going ahead. And I certainly didn't try to uninstall any of the virtual ports again.
I don't mind having to install the ports manually. As a matter of fact, if you can tell me where the necessary inf, cat, etc files are, I will just do a custom install without the virtual driver. I could then install the driver for each port after creating them in Bome. I'm sure that's not ideal, but it will probably work.
My concern is the possibility of having my machine trashed again. Here is some information re my setup:
-latest demo version of Bome
-Windows 10 version 1909 (18363.719)
-Dell XPS 15 Model 9550 32GB ram
The machine checked the hardware after several attempts to get past the POST. This was before I recovered the OS and there were no errors found.
I would very much like to get this sorted out so that I can purchase the software. I believe it is unique in its segment. Seems there is very little it can't do. But stability is of prime importance.
Your help and guidance will be appreciated,
Graham
