Thomas Thai
2020-03-14 00:56:21
The Wacom Intuit software can set up different profiles for different applications. It's preference settings automatically detect the running applications (Davinci Resolve, Notepad, Gimp, etc.) to allow you to configure settings for the tablet and pen tailored to that application. When I'm switching between those applications, it automatically uses corresponding settings.
In BMT, I have presets for different programs. Perhaps I missed some options but I can't seem to automatically turn on certain presets based on the active program I'm using. For example, say I have presets called Davinci Resolve, Gimp and Blender in one BMT configuration file. All three presets are unchecked by default. I open Gimp. I would like BMT to automatically checkmark or enable to Gimp preset. Then I switch over to Blender and BMT disables the Gimp preset and enables the Blender preset.
What I am currently doing is to load specific BMT configuration files for specific programs or manually disable/enable specific presets.
