Tetsuya Ito
2020-03-17 05:01:17
About MIDI Translator Pro.
I want to register Midi SysEx as "Incoming" and use it as a trigger.
However, the received Midi SysEx contains unnecessary information,
and I want to recognize only the second last information as below and use it as a trigger.
"F0 XX XX XX XX XX XX && F7"
For example, in the case of SysEx above, the "XX" part changes each time,
so I want to recognize only the value of "&&" and use it as a trigger.
I want to ignore the "XX" part.
What kind of settings are required for operation?
2020-03-17 05:16:00
OK, so if you don't want to use the XX just specify a local variable and never use it. So
F0 pp pp pp pp pp pp qq F7
Would be the incoming trigger that would recognize any 9 byte Sysex. The in rules, you just manipulate and/or output the qq portion for output.
So output for anote on might be
90 01 qq
I suspect though you might want to qualify some of the other incoming bytes with their actual values to illimatate 9 byte sysex that you do not want to process.
Tetsuya Ito
2020-03-23 05:53:04
Thank you for your reply.
I tried the method I was taught.
The problem was solved.
Thank you.
2020-03-23 06:02:24
I'm glad it helped!
