Browser up/down encoder to keystroke MT pro
traboule_kabbal
2020-03-28 16:06:35
Hiya!
I'm trying to map an endless encoder to browse up/down my tracks; sending keystroke up/down.
Pretty much what's in here https://www.bomeloft.com/forums/viewtopic.php?t=2347
But when I reach 127 I cannot go down, when I reach 0, I cannot go up..
So I added some more rules:
if pp==127 then pp=0
if pp==0 then pp=127
So it would reset the encoder value but it's not working.
So I set it up to activate a preset that sets encoder to 0 when 127 reached with a delay, and activate another when 0 is reached thats sets it back to 127 still with a delay. I mean it works but I'd like some more easy/stable setup..
PS: I cannot edit the encoder to relative mode in the controller editor because the remote script in Ableton overides it, and sets it back to absolute mode..
How can I solve this?
2020-03-28 16:30:32
Please see the attached file. There are two ways to address this type of issue.
  1. Use a timer to send up keystrokes at a given rate if the encoder is above a given threshold and a down keystroke if it is below a given threshold.  For instance from 0-54 send down keystrokes continuously. If 74-127 send up keystrokes. If between 54 and 74, kill the timer so keystroke stop.
  2. Use a button to disable output while you adjust the knob to give you more room for the knob.
Preset 0 in the attached file uses the timer method.  Preset 1 uses the button method.  Only enable one or the other depending on the method you want.
Hopefully this will give you what you need.
Absolute-Encoder-to-Keystroke-2020-03-28.bmtp
traboule_kabbal
2020-03-28 18:23:29
Hi Steve, thanks for your super fast answer !
Yeah I saw way 1 already in your tutorial https://www.youtube.com/watch?v=yjgmIUIS0SI
To be honest I prefer my solution, its actually working perfectly :) (its just that for me its not the best as I layer traktor/ableton on same midi channel so the remote script is interfering..)
I attach it for you to try it out, just remap all translators to 1 encoder !
Have a great day
Endless encoder.bmtp
2020-03-28 18:39:15
Yes, this will work with encoders that you can change values remotely but not with pots or faders (unless they are motorized faders). Thanks for sharing!
