Relative encoder to absolute control *speed change*
lukshanm
2020-04-02 16:24:56
Hi , My Relative encorder is too slow when it's translated to absolute control .
I have no idea about scripting midi  but i used the preset file on the youtube and it worked (Convert 3F/41)
NOW i'm having a trouble with it's speed ! what shoud i do ?
How to change the incoming value?
2020-04-02 18:26:00
Hi, please try the attached. I added an accelleration factor of 3 (tt) to the input.  You will need a different global variable to track each encoder that you need to be absolute. I used ga here.
2020-04-02 18:26:37
Whoops forgot the attachment.
Rel-to-Absolute-w-acceleration.bmtp
lukshanm
2020-04-02 21:10:05
I still dont inderstand the midi concepts ! i uploaded my project file could you modificate it ?
Rel to abs.bmtp
2020-04-02 21:29:10
Ah, I see this is a 3F/41 type encoder. This is even easier. See attached.
Se just take the incoming differential value and adjust for positive or negative and multiply the incoming value by 3 and then add (or subtract) that from the original value to get the new value.
Rel-to-abs-Steve.bmtp
lukshanm
2020-04-02 23:46:52
thanks a lot ! it's working
2020-04-03 02:33:23
Glad I could help!
