Helmut Schneider
2020-04-15 08:46:36
Hi there, how can I use midi Translator Pro to jump between different applications in live use?
Helmut Schneider
2020-04-15 08:46:36
2020-04-15 16:18:04
On Windows, you should be able to send keystrokes Alt(Tab).
On Mac, you could also use outgoing action of AppleScript outgoing action to switch applications.
In either case, MT Pro is not "application aware" so if using Alt(Tab), you will have to ensure you have the count of your keystrokes correct so that you are on the right application.
You might also use the operating system platform to set up special Hotkeys for given applications and use those instead.
ryanconnarton
2020-04-23 03:50:40
For Windows:
Windows Key+1; Windows Key+2; Windows Key+3; and so on - those commands will open applications in the order they appear on your Windows taskbar.
2020-04-23 04:23:02
Helmut Schneider
2020-04-23 08:59:16
