load native settings ERROR
Ofer Smilansky
2020-04-21 14:01:36
Hello
Since a few days I get the following message everytime I restart my computer.
I tried reinstalling bome network, I am not connected to the bomebox or to any other network cable, just wifi and some loopback 2.0.0.1 127.0.0.1
Windows 10
"1: load native settings ERROR: exists, but corrupt. last modified=2020-04-20 09:04:28 filesize=403 filename:C:\Users\****\AppData\Roaming\Bome\BomeNet.bmts
WARNING: overriding settings file with backup (native).
load native settings ERROR: exists, but corrupt. last modified=2020-04-21 13:49:57 filesize=403 filename:C:\Users****\AppData\Roaming\Bome\BomeNet.bmts"
Whats up?
Ofer
2020-04-21 14:37:17
What version of Bome Network are you using?
I suspect that for some reason the settings file in the folder specified is corrupt. Simply remove the BomeNet.bmts file and it should regenerate itself as an uncorrupt file. With that said, it is possible when doing so, any previous memorized connections may be lost so you may need to accept or initiate them again.
You may need to shut down the Bome Network application to remove the file. If you can post the or email me the file, I will take a look to see what might be corrupt.
The file path is
%APPDATA%\Bome
and file name is BomeNet.bmts
