Justin L.
		2020-04-22 04:41:05
	So lets say I have a knob on a controller, has values from 0-127, obviously.  And I want to convert that knob's value to a note on/off... Specifically that at value 127 it sends a note on value, but any ANY other value 0-126, it will transmit a note off instead.
Is there a way to convert a specific RANGE of values to a note on/off such as this?  Some sort of variable and if-then or less than script?
I am new to BMT and have not quite gotten into the nuts and bolts of the rules and variables of it all yet.
Thanks ahead of time.
		2020-04-22 05:28:22
	Sure,
Please see the below example.
The rules set the crossover point.
We compare the current input value to the last known input value. We subtract both values from the crossover pont. We do this so that when we multiply them together if they are both on the same side of the crossover point the value is positive and if they are at opposite sides of the crossover point the result is negative.
If the result is negative (we crossed over)  we output a note with velocity of 127 the new value is greater than the old value (note-on) or output velocity of 0 if the new value is less than the old value (note-off)
If the result is positive (we did not cross the point) we suppress the output so you don\'t get duplicate note messages.
Here are the rules
// cross over point
ss=64
// determine if we crossed
// get last value
rr=ss-ga
// get current value
tt=ss-pp
// Multiply to check if we crossed
uu=rr*tt
// If negative then we crossed
tt=0
if uu<=0 then tt=1
// EDIT had to move this up from original posting so that ga is always updated for  next iteration Make sure rules in the attached file match this.
ga=pp
// we didn\'t cross, so skip
if tt==0 then exit rules, skip Outgoing Action
qq=127
if pp<ss then qq=0
