john.samuelson
2020-04-28 18:09:02
Hi there
I'd really like to use my Nanokontrol to control the filter on my Elektron Digitone. The problem is that the Digitone is expecting the following (see image) and I don't know how to convert a simple CC (eg 74) into the more complex / combined LSB / MSB values that the Digitone is expecting.
Would anyone be able to help me please? So something like - take Nanokontrol channel 4 CC 74, translate that into the Digitone's format...?
Many thanks,
John
2020-04-28 19:29:45
Hi, each parameter will need to be controlled by a different CC. I've included a project file here for CC74 to handle Filter Frequency and CC75 to hanled Resonance.
Of course you will need to set up your Digitone to recognize NRPN. I think this is set up in settings somewhere.
You should see what I did. I simply plugged in the proper NRPN MSB and LSB values into the outgoing action and pass through the incoming value of qq untouched.
