Octave up
alan.karyl
2020-05-10 11:41:02
I’m having great difficulty following the YTube tutorial on translating incoming midi notes up one octave. Seeing that this is probably a common ask, I was wondering if there is a saved file for this that I could download and import into MT and use as a vst. Many thanks.
2020-05-10 15:56:53
The tutorial I did was for a 7 note transpose, not a full octave, however with the change of one value in each of the translators of the attached file from 7 to 12 it should work for you.
I'm assuming you are referring to this tutorial:
https://youtu.be/KMOr4-VeAO0
Note-Transpose-2017-08-01.bmtp
