pedro.estrela
2020-05-31 23:29:25
The manual clearly says mouse event injection is windows only. I use this to change the preferences window of traktor.
https://maps.djtechtools.com/mappings/10575
Just wondering if a) supporting this in macOS is on the roadmap
and/or
b) if you ever heard of any mouse workaround that people did, like (say) having another third party sofwtare that forces a certain window in a fixed location, so that BOME can click there in absolute coordinates
thanks
2020-06-01 02:30:15
I think the way to do it on Mac is with AppleScript which Bome MIDI Translator support on a Mac.. I know the Applescript "tell" and "activate" command can activate a given application.
tell application "application name"
activate
tell application "System Event's"
keystroke "Hello World"
end tell
end tell
pedro.estrela
2020-06-01 15:14:47
thanks, sounds definitelly doable.
BOME can send variables to applescript, applescript can click applications:
https://apple.stackexchange.com/questions/266784/how-do-i-make-the-mouse-click-at-current-location-using-applescript
