Tracking physical key with current sate/variable?
traboule_kabbal
2020-06-13 20:37:06
Hiya :)
I'm trying to configure something but I can't make it work so far,
-pressing physical key Q outgoing mouse wheel up
-pressing physical key D outgoing mouse wheel up aswell
I'd like the outgoing action only if I switch between Q and D, not if I press Q then Q again (or D then D again)
This is why I think I'd need to track the variable of both Q and D
I attached my file, it is working with basic preset activation/deactivation but it seems to "swallow" the physical key message somehow
Any idea on how I can solve this?
d2 switch sorc test - Copie.bmtp
2020-06-13 20:59:25
Hi, MT Pro never swallows incoming key actions. The are always passed through to the currently focused application. If you open a text editor while pressing Q and D you will see this. It does not show in MT Pro because MT Pro is not passing the keystroke. The operating system is handling it directly.
Regarding your mouse movement, I just put a 50ms delay on outgoing action of your two translators and everything works fine.  I suspect the operating system needs a bit of time to process the keystroke first before handling the mouse wheel action.
traboule_kabbal
2020-06-15 11:34:04
Hiya oh ok but in my game it does swallow it :) doesnt matter anyway Thanks for your input and super fast reply, really appreciate it !
