Mid knob control of jog(scrub)
Jose Carlos Heredia
2020-06-29 14:48:02
I would like to make a midi knob(pan, send) to control the Jog wheel so that I can scrub audio in the daw wave view for song editing.
Please help
2020-06-29 16:09:38
What DAW are you using?  Does the DAW support keystrokes to scrub left and right or are the specific MIDI messages for scrub for the DAW?
If keystrokes, you can check on the tutorial below that was published yesterday. Instead of zoom-in ans zoom-out keystrokes, you would use scrub right and scrub left keystrokes.
https://youtu.be/TS24LR1TdGY
Jose Carlos Heredia
2020-06-29 16:24:10
Ableton Live 10
2020-06-29 16:51:14
Just change your output from NUM+ and NUM- to  Right Arrow and Left Arrow.  If your relative controller sends a different CC,  or encoder type, you may need to also modify the input to match.
Relative-to-Keystroke-Scrub.bmtp
Jose Carlos Heredia
2020-06-29 22:41:25
Thank you very much for the quick response.
Got it working.๐Ÿ™๐Ÿ‘โœŒ๏ธ
2020-06-29 22:50:44
Glad to hear!
