gabrielsmarcello
2020-07-09 17:49:45
Good morning, I just bought the midi translator pro and it is wonderful. I would like to ask you
how much will it cost to make a hui translator full from vs 1680 roland to protools 2019.10
and from protools 2019.10 to the roland vs 1680 in euro.
Can you please reply.
my email adress is gabrielsmarcello@gmail.com
Thank you very much.
Marcello Gabriels.
2020-07-09 21:56:29
Hi Marcello,
I received your email and responded. Lets follow-up with email only since this is beyond the scope of free Bome support.
2020-07-10 15:38:57
Hi Marcello,
According to the manual, the VS=1680 sends out CC7 on MIDI Channel 1 for fader 1. If this is true, the attached project file should work for you for just that fader. Hopefully this can get you jump started.
I tested with Cubase in HUI mode.
It also provides the necessary HUI ping response that Pro Tools will require.
The first translator sends a fader touch message.
The second one sets a timer for release once you stop moving the fader/knob
The third actuall translates from CC to HUI Fader Movement
The 4th actually sends the fader release message
Finally the 5th translator provides the ping reponse.
In the second preset, we simply caputure what is coming back if you move the fader on your DAW to the global variable ga. In this example, since we are using absolute CC message we don't use it but if your encoders are relative, it may be necessary to capture the current fader value so that we know what to send when converting relative to absolute.
gabrielsmarcello
2020-07-10 17:03:55
THE HUI WORKS GREAT AND GOOD WITH PROTOOLS 2019.10 THANK YOU VERY MUCH FROM THE VS ROLAND 1680. THANK YOU SO MUCH.
Marcello Gabriels.
gabrielsmarcello
2020-07-10 17:05:21
THE HUI WORKS GREAT AND GOOD WITH PROTOOLS 2019.10 FROM THE VS ROLAND 1680. THANK YOU SO MUCH. Marcello Gabriels.
2020-07-11 02:36:19
Awesome. This tells me the other stuff should be pretty straight forward then and probably more dependent on Pro Tools specific implementation of HUI.
gabrielsmarcello
2020-07-11 12:19:14
Thank you. The HUI works very good it doesn't say in PROTOOLS HUI doesnt work.
IT is a matter of putting the HUI in the last line with the reply like you did, and selecting the correct HUI PORTS from the PERIPHERALS setup.
Thak you again.
Marcello Gabriels.
2020-07-11 14:49:22
Hi, yes I put a short video together in the past for a clent using Pro Tools on how to set it up. Here it is.
https://youtu.be/uQ-FxHup5cI
gabrielsmarcello
2020-09-08 10:47:56
GOOD MORNING BOME SOFTWARE CAN YOU PLEASE HELP ME, HOW TO SETUP THE
MIDI ROUTER I CAN'T SETUP THE PORTS IN PROTOOLS WITH OUT THE MIDI ROUTER
I FORGOT TO WRITE IT DOWN PLEASE HELP. THE HUI STILL WORKS BUT NOW IT SAYS THE ERROR MESSAGE SETUP PERIPHERALS IN PROTOOLS.
PLEASE HELP.
THANK YOU VERY MUCH.
MARCELLO GABRIELS.
