Akai Apc Mini Help!!!
henrikvillwock
2020-07-22 23:22:40
Good evening. I have a big problem with my apc mini from Akai. I use the apc for my lighting control (GMA2 on pc) and now I have a second apc. Since three days I want to build a new preset for both apcs  but it doesn't work. I am desperate. i need a preset for two apcs with output channel 1 and 2. does anyone have such a preset? thank you
2020-07-23 23:17:59
Hello,
The way to set CC to note translation on your first APC-MINI which I'm sure you already have on MIDI channel 1. You should define the input at the Preset level for the first APC MINI only.
Then set up a separate preset for APC MINI 2 only and a translator to translato all incoming notes and CC to MIDI Channel 2.
In this preset you will need 3 translators
Translator 1
Incoming: Note-On MIDI channel 1 any note set to pp any velocity set to qq
Outgoing: Note-On MIDI channel 2 note pp velocity qq
Translator 2 - Same as above except for Note off
Translator 3
Incoming: CC on MIDI CH 1 any cc set to pp any value set to qq
Outgoing: CC on MIDI CH 1  CC pp and value qq
In both presets, you want have the output defined as whatever virtual port you have set up for GMA2.  Again the first preset input only from APC1, second preset, input from only APC 2.
I hope this helps!
sebadem1987
2020-07-23 23:21:25
Nevermind lolz
