NormtheMusician
2020-08-08 13:57:43
I've spent ages trying to work this out and I've failed.
I'm using a launchpad 2 to control keyswitches and everything works fine, but I can't work out how to get the pad to remain on when selected.
If I do this, then the BOME remapped pads don't work.
I'd just like to be able to know which pad(s) are selected at any given time, and to be able to cancel the lights which a press of one particular button (could be the escape key I suppose).
I've tried experimenting with the demo of flashing lights, but that seems to put the launchpad in a mode that isn't compatible with note outputs.
The launchpad program manual doesn't seem to help here - perhaps there is a special mode it has to be set too to do this.
Any help appreciated - I don't really want to have to buy a different launchpad if I can help it, although I know the very latest can be programmed without having to go through BOME.
2020-08-08 15:52:44
Please find the attached.
The Launchpad buttons are all momentary. We have to convert the LED behavior using Bome MIDI Translator Pro to toggle to track the on/off state of the LEDs.
In this case I use two global variables (which are 32 bits each) "ga" and "gb" to track the on/of state of the 64 square pads. If you want to also track the round ones, you will need another global variable.
I use the power up mode of the Launchpad MKII to determine note numbers.
The rules work as follows:
- I calculate the global variable and bit position based on the incoming note number by first converting to rows and columns. Then from there I determine the bit position. (The Launchpad note numbers are not completely sequential but bit positions should be).
- I toggle the bit of the button pushed and then re-save the global variable
- I send back either note-on or note-off values back to the Launchpad depending on the current bit state
- The preset defined input and output is My LaunchPad which are aliases that I define as my controller. Application is an alias I also defined. When opening the project the first time, you will be prompted to assign these aliases to their real ports. After that you can use the menu MIDI->Edit Project Port Aliases to re-assign them if needed.
I also set up a thru path from My Launchpad to Application to allow the buttons to pass thru to the application untouched (momentary). I am assuming you do not want to modify the behavior of what you are sending to the application. I also turned off "swallow" in the translator to allow the note-on messages to pass through this path untouched.
The rules are heavily commented. This is a pretty advanced technique and you could always use 64 translators and 64 global variable instead, but I prefer to conserve global variables and also use fewer translators whenever possible.
I hope this gets you on the right path!
NormtheMusician
2020-08-08 18:24:39
Thank you !
I'm experimenting now and I'll let you know how I get on!
