cogem74
2020-08-11 16:16:51
Hi Steve, in the end right now I am only using Davinci resolve keystrocks
with the classic program.
So in the past I have not been able to make pots work as contrast, pivot etc.
with the bone pro program.
I would like to try again, could you explain me in detail how to do it or
attach a project to me?
I remind you that I use win10 and arturia beatstep
thank you
2020-08-11 17:02:45
The following tutorial should cover it. Just set up your Arturia Beatstep encoders as relative.
https://youtu.be/TS24LR1TdGY
cogem74
2020-08-12 11:16:57
Hi Steve, unfortunately Davinci Resolve for contrast, pivot, sat etc. it has no keystrocks but only a small window in which the internal values move with the mouse.
Hope you can help me.
thank you
2020-08-12 15:15:24
Hi, yes you can move it with mouse click and drag, however your mouse coordinates need to be precise and the Davinci Resolve Window (the area you click) will always need to be in the same place.
The below thread may help get you started with how to move a mouse with an encoder (although the encoder type in the example below is with a MIDI Fighter Twister so I believe the relative values of the twister (63,65) are different than the BeatStep (127,1).
https://www.bomeloft.com/support/kb/knob-to-mouse-movement
