Minimize to tray
Michael Rush
2020-08-13 22:13:52
Hi Florian,
I own Midi Translator Pro and love it. I use it to integrate an old JL-Cooper controller and a Hammond SK1 to Cubase and it works super well for my needs. For that reason I always have it running so I'm wondering if there's a way to make a minimize to tray feature. I use a program called RBTray to add this functionality but I'm wondering if there's a way to make it a native function?
Michael Rush
Vancouver, Canada
2020-08-13 23:31:23
Hi, yes. On Windows to Start Minimized Go to the View Menu then Startup, then check "Start Minimized"
Then after running, if not minimized, you can go to View->Appearance and check "Minimize to Tray" and if you want the traaay icon to show, make sure you have "Show Tray Icon".
On Mac it is similar but the it is on the Bome MIDI Translator Pro Menu instead of the View Menu. Then Preferences.
Michael Rush
2020-08-13 23:47:29
Thanks Steve! It was right there in front of me the whole time!
