JimDaneker
2020-08-25 05:20:56
Howdy,
I'm using a massive 4k monitor, and MT always maximizes to fill the entire screen when launched - I always have to manually set it to the size I want, which is about 1/4th of that size. Is there any way for the app to remember that so I don't have to do it every time?
2020-08-25 05:46:38
Hi Jim,
Are you on Windows PC or Mac. I'm on Windows and wherever I leave the window when closed is where it opens up the next time I launch MT Pro. So if it is maximized when I close it, it is also maximized when I open it. If I close it from the second screen maximized, when I re-open it opens on the second screen maximized.
JimDaneker
2020-08-25 17:45:21
Hey Steve, sorry I forgot that bit of info. I’m on Mac OS Mojave (10.14.6). I’ve tried resizing the window and saving the file, but it always opens to full screen no matter what.
2020-08-25 19:36:47
Yes it appears to be an issue in 1.8.4. I believe this is being worked on and expect a fix in the next version of MT Pro.
