MIDI monitor on BomeBox?
Eleanor Saitta
2020-09-02 14:41:02
Apologies if this is a FAQ, I couldn't find it in the docs.  Is there a way to monitor midi from the web interface on a BomeBox, or do I need to send a copy of the stream over the network with the network driver and monitor it locally?
2020-09-02 16:37:38
Currently you need to stream the MIDI output over the network to your PC and monitor the output there. Of you could use any MIDI port if you have some sort of MIDI monitoring attached to it.
Eleanor Saitta
2020-09-02 17:17:19
