Digital Sensei
2020-09-06 00:58:02
I use a product called aerodrums that outputs midi signals to play games. Think of it like an electric drum kit basically. I need to be able to strike one drum to press a key down and hold it until i strike the same drum again.
All I can think of for now is to use a very long timer on the key up delay and have a seperate drum to be a global Key up command. But that will be a hassle. Any insight?
Digital Sensei
2020-09-06 01:34:09
I had the idea of maybe creating some sort of feedback loop to hold down the same note that i'm using to input.
so like when I strike CH10 note 38 (the one i intend to use) it would output ch10 note 38 indefinitely, then have a second translator to turn that note held down into a keypress being held down. But I'm still not sure how i'd program the same note to also trigger a note off the next time i pressed it without the repeated "note on" canceling itself out by triggering the note off.
2020-09-06 02:42:21
So you want it to on first hit, send keystroke down and on second hit send keystroke up and so on?
2020-09-06 03:32:35
Hi Something like this will work.
I use a global variable ga to track the key state. I toggle it so that it moves from 0 to 1 and 1 to 0 on every key press.
The first translator only fires if ga=1 and presses the "a" key down. The first tranlator also performs the toggle
ga=ga^1
The second translator fires only if ga==0 and sends keystroke "a" up.
I hope this helps!
Digital Sensei
2020-09-06 03:56:30
That worked perfectly! I just had to set gg as the variable on the second input i needed to also act that way. Thanks a lot! I had a feeling i was overthinking it a bit.
2020-09-06 06:31:06
Glad to have been of help!
