nolascofoxx
2020-09-08 04:43:21
As in the title I am looking to translate keystrokes, namely num1, num2 etc into Momentary midi cc commands for use in ableton. Is this possible? I have only got as far as getting them to toggle which is no use as I could just use the key mapping in ableton. Some kind of coding I must implement? Thanks
2020-09-08 04:58:59
It can be done, however the original keystroke will not be supressed so if it used somewhere else on your computer, it would still perform the original function.
nolascofoxx
2020-09-08 06:45:01
Cheers for getting back Steve, how can I go about making it momentary? What should I look into learning? The numkeys are'nt really used so I am not too bothered unless its possible to suppress their function as well?
2020-09-08 14:38:09
Yes, the below example should get you there. I look at Num0 down to send CC0 at value 127 and Num0 up to send CC0 at value of 0.
nolascofoxx
2020-09-08 18:48:47
You're a legend Steve, thank you
