Chris Cheetham
2020-09-22 20:43:06
Hi. Do I understand it correctly that to create translator rules on a Bomebox, I need to create them in the MIDI Translator Pro application, and then transfer the .bmtp file to the Bomebox?
So if I buy a Bomebox, I also need to buy a MIDI Translator Pro license? or is the license included in the hardware purchase.
2020-09-22 20:49:14
You are correct. and yes if you want to run rules (instead of simple MIDI routing) on BomeBox, then you will need a license for Bome MIDI Translator Pro as well.
2020-09-22 21:08:52
You will also need to purchase Bome MIDI Translator Pro license if you want to use create rules for BomeBox.
