tito97gst
2020-10-25 17:00:59
Hello guys,i had a question about how top get the 64 pads on the launchpad to light and how to asign a specific color to them and toggle on/off state and be able to map to a keystroke so thank you Steve for sending me a preset file, it helped greatly. however i want to able to do the same with the round buttons, how can i do that? which variable can i set for that. i attached the file I'm using.
Thanks again.
2020-10-26 00:31:36
To do this you would need to do something similar to what I did for the main matrix.
Set up a bit map with the top row and right side to reflect the button states.
Set up a timer to iterate through the buttons at project start.
If you need this done for you, this would be paid support. I see you sent me an email so I'll respond with an estimate there.
tito97gst
2020-10-26 21:53:15
Hey Steve,
I just loaded the preset and I'm very happy with the results . thank you for your time and work.
