emilio_n
2020-11-14 13:11:07
Is BOME MIDI Translator Pro Big Sur compatible?
emilio_n
2020-11-14 13:11:07
2020-11-14 14:24:57
I don't believe it has been yet tested with Big Sur. I'll see if I can load it on my MacBook Pro after upgrading to Big Sur and let you know.
emilio_n
2020-11-15 05:11:46
Thanks, Steve!
I will try to test it as well. I don't want to update until check my most important software is working and Bone Midi Translator Pro is a key part!
Emilio
2020-11-15 19:14:13
I've done some basic tests and everything seems to work OK. If you want to be safe, maybe wait a bit more in case any issues turn up. I would be more concerned about various Daws which might have more dependencies with the OS.
