peter.antal.music
2020-11-19 09:34:35
Hello, im totally new to Bome and midi in general, sorry for sounding ignorant. I managed to assign keystrokes, but my Push 2 to rotary knobs seem a bit more complex. I would like to be able to control with one of the knobs the horizontal directions, and an other knob the vertical ones. How do i do this?
thank you
Peter
SteveC
2020-11-19 15:40:10
Hi, Peter and welcome!
Not knowing whether your Ableton Push encoders send absolute or relative values, this video tutorial may or may not help. For mouse movement it would be better if you can set your encoders to relative mode if possible.
If you still have problems, please turn on the log Window in MT Pro and select MIDI IN and turn your knobs so I can see what they are sending. Please annotate the MIDI messages to show which knob you are using, which way you are turning it, and the desired mouse movement you want.
peter.antal.music
2020-11-19 21:09:17
Hi Steve, thank you for your answer, this is great info.
However, im not trying to control the pointer, but the mouse wheel. Do you have a video for that? :)
SteveC
2020-11-19 21:47:26
Yes, see the link below:
https://youtu.be/ZGzbfrmzjTc
peter.antal.music
2020-11-19 22:53:06
YES!!! you guys are awesmoe. Thank you! Works!
