Jaco
2014-03-21 05:03:46
I am a relative new user to this software, really keen to get it the MIDI to HUI protocol going for the purposes of using my A&H Zed R16's MIDI out with Pro Tools 11.
There seems to be a routing problem though, After downloading the presets from A&H's website and setting it up step by step by their instructions, I am still getting no output messages from MT.
From the event monitor and the log window it shows the midi input messages but with no corresponding midi out messages with the exception of HUI clock messages
From my knowledge the virtual out ports are correctly routed as A&H specified in their setup guide... Is there like an "on" switch I am missing or something? It seems the solution is really simple but I have spent hours without any luck.
Running Mac OS Mavericks with Pro Tools 10/11 with MT trial.
