Hi guys, thanks again for the time and effort. Just wanted to update you on my situation:
Florian, the function did work to make a curved fader response, unfortunately I couldn't get it to meet my needs. In my specific case I needed a faster response early on in the curve and I couldn't get what I needed by raising the scaling factors.
Fortunately I was able to tweak my original rules to get it to sound very good. The speeding up affect of the multiplier from 0-20 on the fader actually served my purposes very well and I just needed to slow it down in the right spot and I slowed it down further near the end of the curve by using pp/2.
FYI, what I needed this for is absurdly difficult to explain, but maybe ile try just for fun
Bear with me if you're interested in some interesting performance rig challenges:
Im working on a 4 deck DJ setup running Traktor in external mixing mode so I can run the 4 tracks independently out to Ableton and then have separate Ableton effects on each track. Then im running 2 output lines from Ableton on my 2 output line Soundcard. 1 line Master, 1 line Preview. I also have an APC 40 controlling it all, Traktor and Ableton. Its a great setup, but it creates some issues.
Traktor has an option to have pre-effect faders, so that I can use Traktor's reverb and fade out a track while the reverb tail persists for example. I like this feature but this forces me to use the Faders inside of Traktor. I cant use the Ableton Faders to fade out a track now because the signal is mixed with the reverb when it hits Ableton.
Now this creates a problem for previewing tracks! Traktor in external mode doesnt have an extra line out for previewing tracks. The only way to preview a track would be to have the fader on that track be up in Traktor. Thats the only way a signal would get to Ableton and then I could route it into the Preview channel. So the challenge was to figure out how to preview a track without having it go to the master channel. 1 option was to temporarily have the APC40 fader control the Ableton faders while the Traktor fader was up to full while previewing that track. But that turned out to be too restrictive and it meant I lost the ability to use the pre-fader effects tricks while previewing a track. I wanted something more natural and I came up with a crazy little solution:
When I click to preview a track, it sets the Traktor fader to a super low fader value of about -60 db. This is not enough to be heard out the master. Then I have separate preview channels in Ableton with + 60 Gain utilities in the channel. When I click the preview button, those channels are activated and send their signal to my headphones. The signal I get is at full volume.
The challenge at this point is what happens when I raise the fader while the track is still previewed. The Traktor fader rises quickly at first and slows down as it approaches 0 db. I have to compensate for the increase in gain by decreasing the gain on the Ableton channel otherwise my ears blow up. This is where the need for a curved fader response comes in. I needed the decrease in gain in Ableton to match up close enough to the increase of gain in Traktor to keep a relatively steady volume. I managed to accomplish this with those rules I mentioned.
Anyone that took the time to read this I commend you! lol. Im definitely developing one crazy rig here. I plan on making a youtube video showing off the bells and whistles when it is done, and I will definitely share it with you guys. It is definitely only made possible by your product, so I very much appreciate you guys!
