garubi
2014-03-25 10:01:30
Hallo, I'm a Bome's Pro user since several years! Thanks for this wonderful program!
I'm programming a new setup where I'm using some note ON messages to switch between presets of a VST.
I have no problem with the basic script, ie press the key -> apply my translations -> send the note message to the vst
I need your help for the following "problem":
The VST change preset only if the note ON message it receives is long at least 100ms, otherwise it ignores the command.
The VST author designed it this way to avoid accidentally preset changes.
I would ike to setup Bome's Translator so even if i push a button for less than 100ms it sends out that "note ON" message for 100ms
I think I'll have to use some timers but since I never used them and they are a little confusing (for me, obviously) any help from you would be very appreciated!
Stefano
Stefano
