double click (left mouse button)
gutschein
2014-04-14 16:35:29
Hi all,
how can i make a double click (left mouse button)
I look in Outgoing/Mouse
- Button click
- Left
Many thanks
DvlsAdvct
2014-04-14 16:47:30
Hi gutschein
There is, unfortunately, not double click command, but we can use a repeating timer to "fake" a double click command.
To do this we need to use one incoming message which will trigger a timer which will send out twice at a pre-determined interval. Every time the timer triggers it will activate a mouse click. It should look something like:
Translator 1: Button Press
Incoming Message: 90 40 7F
Outgoing Message: Double Click Timer 0ms delay Multiple Times: 2 Repetition Delay 10ms
Translator 2: Timer
Incoming message: Double Click Timer
Outgoing Message: Mouse Button Click Left
Each time you press the button the timer will trigger twice and the mouse will click twice. You may need to play around with the Repetition delay to make sure it is accurate.
Hope that helps
Jared
gutschein
2014-04-14 23:01:24
many thank.
I dont understand.
I get 1000 klicks.
Please look my screenshots
dopellklick.pdf
(213.65 KiB) Downloaded 166 times
DvlsAdvct
2014-04-14 23:42:10
Set the multiple times to 2 instead of the default of 1000
gutschein
2014-04-15 05:53:18
Many thanks it works great
