fx-petal
2014-05-16 08:36:37
I recently bought a Presonus Faderport to use with Reason. I really should of done more homework as it's not a native device. After shelving it and posting it on ebay I found out about MT, so I've decided to download it and give it a go. SO!
I've got my MT (Classic) running and I've created a new Preset. So far I've added two translators just to see if I can get things moving. I've decided to go with STOP and PLAY. I've set my incoming triggers to capture midi.
For my first Translator "STOP"
- My Incoming Trigger is CC#1: Controller 47,3
- My Outgoing Trigger is CC#1: Controller 47,0
For my second Translator "PLAY"
- Incoming Trigger is CC#1: Controller 47,4
- Outgoing Trigger is CC#1: Controller 46,0
Reason doesn't seem to recognize the ,3 or the ,4 value and was only receiving the Ch1 CC 47
I thought I was getting somewhere when I worked that out. Unfortunately I can now assign each button to the transport controls in Reason but still nothing happens when I push the hardware controller. I've added the control surface in Reason's list of controller and set the midi to receive on the same channel that I've set to send on MT. Is there something I've missed?
Also I'm still unable to have Reason or MT pick up on a midi signal from my Fader! Should I be worried?
