Mister36
2014-06-01 12:03:39
I have been trying to use MIDI Translator recently and have succeeded in getting it to do what I want it to, but every time any of my various USB-MIDI controllers becomes disconnected from its socket, MT seems to rescan the ports and lose connection with the only one I had connected to MT.
I am using MT just for a Nanokontrol2, but am using several other controllers too (that connect directly to other software) and when any of these others are disconnected, it resets MT to no input/output, forcing me to have to restart the program (as an error is thrown when just trying to reset the ports) and then manually reset the ports.
I have tried piping MT with MIDI from a virtual port instead, but it makes no difference. If any of the ports/controllers shown in MT's inputs and outputs are disconnected, MT resets and needs to be restarted. This becomes a real issue for live performance. But is this just the way it is and the way MT works?
Thanks for any comments and help.
