Problems with global variables i0..iz and j0..jz
kendallreid
2014-06-05 23:01:12
Hi! Are these in fact global variables? The manual seems to say they are, however when I try use them nothing happens, no value/s gets assigned when for example I do: i2 = 22, or jk = 33
Thx!
DvlsAdvct
2014-06-10 18:46:04
Hi kendallreid
Yes, those are all global variables. Can you give me an example of a translator your are creating, or attach the project that is giving you issues?
Jared
kendallreid
2014-06-10 19:12:01
I apologize I've done some more tests and its working now. Only one that didn't seem to work was "if" and that is probably because it is a keyword. I did test a few and it wasnt working cant seem to repeat
I noticed that y0-yz, z0-zz are also globals? Helpful as I'm using a lot of global variables. Presuming a-f are reserved for other things?
DvlsAdvct
2014-06-11 00:59:15
Right now the only available global variables are g0-g9, ga-gz, h, i, j, k, l, m, n, y and z.
oo-xx are local variables.
'if' should work, you just need to make especially sure the syntax of your rules line is correct. you should be able to do something like if=1, or if if==1 then...
