getpunchdrunk
2014-06-10 21:09:55
Hi there,
I've been using Bome to control software that requires key presses (1, 2, enter, space, etc...) for a while, and it works great. I used a MIDI controller as the input source, and it translates that to the key presses.
I'm looking to use audio input now instead of MIDI to control the key presses - there are a number of apps available that will translate audio to MIDI, but I'm unsure how to get that data into BOME to then create a key press event.
I'm on OSX, have looked at these two apps as possibles:
osculator . net
midimorphosis
Does anybody have experience or advice on how I could get this setup? Thanks in advance!
- Jacob
osculator . net
midimorphosis
- Jacob
