marc11657
2014-07-08 17:12:49
Not sure if this is because of Bome's, Cubase or because of the particular outgoing Midi Message I have chosen. I'm setting up midi control of Cubase 5 and I've noticed that when I use a button on the midi device to control any of the transport buttons there seems to be a delay before it carries out the function. This is the setup I have and the moment that the delay occurs:
1. I press the play button on the Yamaha AW4416
2. Midi message is triggered (red LED indicator lights up) on Midi IN of E-mu 0406 USB
3. Midi message is recieved by Bome's Midi Translator
4. Bome's Midi Translator converts the Sysex Signal to B0 39 7F/Controller 57, 127. I'm doing this as Cubase 5 doesn't appear to accept incoming Sysex Midi Signals.
5. Bome's Midi Translator sends the converted signal via LoopBe Internal Midi Driver
6. Cubase 5 detects the incoming signal from LoopBe Internal Midi Driver
7. Cubase 5 converts the midi signal to a function (Transport Play)
8. ***DELAY**** The play button on Cubase 5 transport bar illuminates (although the stop button is still on) for about 3-4 seconds before the session actually plays.
Here's some things I've tried or noticed whilst trying to work out where in the chain the problem stems from:
- When I press play using the mouse or the keyboard the session begins to play immediately.
- In Bome's Midi Translator you are able to translate the incoming midi to a key stroke. I set the outgoing to the 'spacebar' and the track played immediately when I hit the play button the the midi controller. However I don't want to use keystrokes to control Cubase as this may cause unwanted effects.
- I used the same play button on the controller and assigned it to 'mute' on audio channel 1. The mute switched on and off immediately and without delay.
- I used another button to of the control surface and programmed it to trigger the play button in Cubase's transport. The delay still occurred
