Digital Gigalow
2014-07-09 21:57:32
Hellow Guys and Gals. I have a new Project I would like some help with. Also, this should be able to work on 3 different controllers by Akia Pro. The APC20, APC40 and APC40mkll all use midi channels 1-8. I have already created a file to allow use of 2 APC40's at the same time. I would like to take that concept and use it on one APC40.
APC40 Objectives:
1. Start up shows clip launch buttons light up Green and using the original midi settings, (channels 1-8).
2. Press the Shift Button and the Clip Launch Buttons turn Red and the midi channels change to 0-16.
When I get this working, i want to do it for the other 2 controllers mentioned above, yet do not on these controllers. If some one would try this setup on them and see if they work and post the file here, that would be GREAT.
This Shift Button will be used to switch back and forth from channels 1-8 and 9-16
Thanks.
APC40 Objectives:
Thanks.
