zenboy
2014-09-09 05:18:55
Hi All,
I've looked in the forums for a solution but could not find an solution to my problem.
I am Using Abelton Live and am controlling it via a Livid OhmRG. I've mapped all the buttons etc. of the OhmRGB to the controls I want and it works as expected. However, I need to use MT to map a few keyboard commands to finish the job. The problem comes in when I try to use MT, Live the OhmRGB at the same time.
I am using MT Pro Trial and have mapped the key commands to the buttons I want. If I start MT first, then open Live I get to use the buttons on the OhmRGB as defined by MT but then all other buttons do not register in Live.
If I start Live first then I get all the controls working like I expect, but when I start MT I get two Error messages:
"Failed to open MIDI OUT device "OhmRGB".
Please connect the device(s) or select another one in the MIDI setup."
as well as
"Cannot open MIDI input device "OhmRGB":
There is not enough memory available for this task. Quit one or more applications to increase available memory, and then try a"
The OhmRGB is definitely connected and I have 32Gb of ram, I do not have low memory.
Any clues what gives and the solution?
Thanks for the help
Zenboy
as well as
Thanks for the help
Zenboy
