nofish
2014-09-12 12:15:15
Hi all, new member here and totally new to MT.
I'd like to know if it possible to convert 14 bit NRPN CC's to 14 bit pitchbend messages with MT (back and forth).
Background:
I have a BCR2000 which I use as a Mackie control emulation.
The BCR can send 14bit pitchbend in principle, but there's a problem when doing so, MIDI feedback back to the BCR doesn't work anymore then.
also mentioned here (post #2)
kvraudio.com_forum_viewtopic.php?p=4353121
(replace _ with /)
So I thought maybe it's possible using 14bit NRPN instead and MT to convert back and forth between pitchbend and NRPN ?
So the chain would be:
- BCR sends NRPN -> MT converts to pitchbend -> DAW (REAPER)
- REAPER sends pitchbend (parameter feedback) -> MT converts to NRPN -> BCR
(I unfortunately can't use NRPN directly to control REAPER parameters because the Mackie implementation cannot be changed to work with other messages than pitchbend)
Thanks.
Background:
(replace _ with /)
Thanks.
