cesarvog
2014-10-24 16:16:05
Good Morning everyone,
This is my first post here, so please forgive me if this has already been answered before, as I searched and found nothing.
I just got myself a new Numark NS7II. Even though it works just fine with Serato DJ, I feel that I have been spoiled by using Torq for so many years with my previous controller, the M-Audio Xponent. I don't want to start an argument about which software is best, I just want to try using my new controller with the old software, because I feel most comfortable with it.
I've already done substantial work identifying MIDI messages sent over MIDI channels to BMT when each and every control (wheel, knob, fader, toggle btn, etc) is moved, in each controller surface. I then created an Excel spreadsheet with the collected information.
So now, if I somehow understood all this MIDI stuff correctly, I figured that, for example, when I press (and release) the Play/Pause button on the Xponent, it sends "90 24 40" (Note On) and "80 24 40" (Note Off), while when I do the same thing on my NS7II, it sends "91 34 7F" for Note On and "81 34 7F" for Note Off.
To validate my understanding of how to use BMT in order to try and fool Torq into thinking I'm still using the XPonent, when in fact I'm using the NS7II, I thought I had to do the following:
1) In BMT: create a translator that would send 90 24 40 and 80 24 40 out every time 91 34 7F and 81 34 7F was received from the NS7II ;
2) Leave BMT running in the background;
3) In Torq 2.0.3, modify the MIDI settings by setting the NS7II as "Inactive", and Bome's Midi Translator Virtual Port 1 as "Active" and as default controller for MIDI IN and MIDI OUT.
The problem is, even though I did set everything as above, Torq does not seem to want to do anything when I press and release the Play/Pause button on my NS7II...
So, can some good soul out there, pleeeease, advise if I am missing anything?
Cesar / Brazil
Cesar / Brazil
