Sacco
2014-10-30 05:53:08
I've checked the help and I swear I cannot find an answer in a nutshell there. I see ports can be dynamically opened but I have no idea how.
I'm using MTP to control different MIDI gear to different DAWs so I need to switch the opened ports back and forth.
The question is:
Am I forced to open ports in the settings options or can I leave them unchecked and open them from the individual translators? If so how? I tried and nothing happens when they're left unchecked and I have set the default ports as well as individual port from the translators.
My plan is to use two Presets to switch modes/ports before opening the software, as opposed to opening the projects and opening the used ports. I guess that would be the intention with the presets so you can even use another gear to control those presets and switch presets with a button, right?
I'm I forced to use aliases too? what's the real benefit of them?
Thanks a lot!!
The question is:
Thanks a lot!!
